Nylez B18C Civic Coupe
This section is intended for international users
Nylez
Bil: B18C Civic Coupe
Namn: Niels Classens
Hi,
I am allready reading the forums for a while, but thought it was time to introduce myself.
Also since i will be moving in with my girlfriend in Jonkoping next January! :)
My name is Niels aka Nylez and i'm from the Netherlands.
Currently i drive a 1998 Civic Coupe with a semi-build B18C engine.
Mijn previous car, EK4 R.I.P. @ Nurburgring
When i bought it, almost bone stock.
Mods:
Intake;
*Skunk2 Pro Series intake Manifold
*Blox 68mm Throttle Body
*Hondata IM Gasket
*Coolchamber
Engine;
*OEM CTR '00 spec camshafts
*OEM CTR '00 spec valvesprings
*OEM CTR '00 spec spring-retainer
*310cc Precision Injectors
*P30 ECU tuned by Bekerom Tuning
Exhaust;
*Hytech Tri-Y 4-2-2-1 Small-tube
*Invidia testpipe
*Invidia GT300 Catback
Suspension;
*K-sports full adjustable shocks
*Stock EK4 sway- and strut-bars
Brakes;
*Nitrac 282mm 16-Groove brake disc
*MG brake calipers
*EBC Yellowstuff brake pads
Exterior;
*OEM EK9 Spoiler
*OEM EK9 Rear Bumper Lip
*OEM EK9 Window Visors
Interior;
*OEM EK9 Red Recaro's
*OEM EK9 Red door-panels
*Stripped out back
Wheels;
*Volk TE37 15x6,5J ET42 4x100 white
After the crash (not my own fault... :( )
So it was time for something else
1998 Civic Coupé (still my daily drive....)
Mods:
Intake;
*BLOX Velocity stack + 3" APE intake
*Professional Products 65mm tapered & portmatched
*Edelbrock performer X intake manifold
*310cc Precision injectors
*Hondata heatshield gasket
Engine;
*Completely rebuild '98spec B18C
(newly honed, new rings, seals, bearings, etc)
*Milled deck & head
(~11.7:1 CP)
*Buddyclub Spec III+ cams
*Spoon oil-cap
*Spoon radiatorcap
*Skunk2 VTEC solenoid cover
*Skunk2 cam-seal
*Hasport engine mounts
*SRR oil catch can
*SRR coolant reservoir
*SRR cam-gears
*Baffled Sump weld-in
*Magnetic drain bolts
*Walbro fuel-pump
*Gates racing kevlar timingbelt
*Arospeed groundwire kit
*OEM Type R (red) valve cover
*Kevlar plugwire cover
*Taylor battery relocater kit
*Fidanza flywheel
*ACT Street-disc clutch
*S80 short ratio gear box with KaAz Final Drive and KaAz 1.5Way LSD
*ITR shift-linkage with short-shifter and shifter-extension
Exhaust;
*RMF replica header
*Adjustable testpipe
*Invidia GT300 (N1) catback
Suspension;
*KW variant 2 shocks
*Energy Suspension Hyperflex Bushing Kits
*Summit 4 point upper rear strut
*Suspension Techniques rear anti swaybar
*ASR subframe brace rear
*H-brace subframe brace front
*Carbing 3 point strutbrace upper front + brakestopper
*B-pillar floorbar
Brakes;
*NITRAC 282mm Grooved discs
*OEM EK9 Brake Calipers
*Ferodo DS2500 brakepads
Wheels;
*1 set 16" 5zigen ProRacer GN+ bronze (will be coated)
*1 set 16" 5zigen ProRacer GN+ coated RSP Racing black
*1 set 15" OZ Superleggera with R888's (track-days)
*Toyo Proxes R1R 205/45/16
*Lightweight aluminum Wheel Nuts
Exterior;
*EK9 Frontlip (wings west)
*Type R grill
*EK9 headlights
*OEM wind visors
*Carbon hood
*AeroCatch hoodpins
*Sideskirts and side-strips in colour
Interior;
*Lancer EVO VII Recaro's
*Sparco suede steering-wheel
*EK9 cluster
*EK9 shiftboot
*DC2 shiftknob
*VDO oil pressure gauge
*VDO oil temp. gauge
*VDO water temp. gauge
*R-Spec vtec controller (JDM DC2 option)
Some shots at the ring:
That was about it i guess! :)
Looking forward to spend some time on this forum and get in contact with the Swedish Honda Tuning world!
With special thanks to:
- Rising Sun Performance
- Assitch
- Bekerom Tuning
- HonTEC
buggs
Bil: 1990 Honda Civic SiRII 1.6i VTEC
Namn: Marc
Poor EK :? So did I understand right you crashed it ON the Ring?
Love the ring pics!
Cheers
Has thanked: 31 times
Been thanked: 23 times
Wow! Nice cars! Too bad the EK4 died, it looked really nice and kinda JDM :D
Welcome to Hondaklubben!
Any future plans for the coup´?
Nylez
@buggs;
Yes, that is correct...
However it was not due to my own fault... :evil:
@Malkolm;
Thanks! Yes, the EK4 was a really nice car which drove fantastic!
However the coupe is a better more stable chassis on the track!
Futureplans... hmm...
Short-term (so i can race again next season!):
- Brake upgrade to 298x32mm floating bell discs with Wilwood 4-piston calipers
- Harness-bar
- QSP Racing seatbelts
Long-term (probably after next season to gain some extra horse-power):
- Port&polish the head, 3-angle valve job, high-comp valves, springs and retainers
- Buddyclub Spec IV cams
- Bisimoto V2 header
- Skunk2 MegaPower R 70mm catback.
And if i can find another daily-drive car, then i am going to build this car only for track-use.
So that would include full roll-cage, stripped out interiour, Lexan windowns, carbon roof, doors, etc...
But that is thinking far into the future! ;)
